Old 09-10-2011, 04:27 PM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by groar View Post
the engine makes a strange noise when it's started with the new switch turned off
it makes the same strange noise when the new switch is turned off while the engine is on
Do the noises go away if you switch it back on after restarting the engine ?
And do the heating plugs fire up after you've started with the switch off , then flick the switch on again ?
