Old 09-13-2011, 04:17 PM   #8 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
It can predict it provided you have modeled every thing right. What I'm saying is things like how smooth the surface is and gaps in body panels on the car are going to have some effect on the air flow that you have to quantify for the model.
Another thing that is very very important is getting a good mesh of calculation points. Too many points and your simulation will take too much memory and time to run. Too few and you won't get valid results. As I understand it there are formulas that can give you a starting point, but knowing this is something that comes with experience and looking at results.
There are ways to go about this to get a good approximation. One method is to model a test case that someone has gone through and tested thoroughly in a wind tunnel and start tweaking parameters in the simulation until you get very similar results. Then you can start testing your model. A common test case for car simulations is the Ahmed Bluff body.
start reading through this thread on this forum
Automotive test case -- CFD Online Discussion Forums
Then get a copy of openfoam running and look at the motorcycle test case and learn how to view the data with paraview.
Sadly my free time is not predictable so I don't have time to learn it to the degree required.
you can also chat with someone on the internet relay chat (irc) on
irc://freenode/openfoam-irc
be patient the people there are from all over the world and in different time zones
Edit: I was told this would be a good link for someone to look at http://www.icaen.uiowa.edu/~me_160/L...medcarrodi.pdf
