Originally Posted by Phantom
Haha stock
"The most remarkable thing about the F-250’s speed is that it the truck remains mostly stock. Ford says that it... only installed a high pressure fuel pump, new fuel injectors, new turbos, and modified the compression ratio... aerodynamic fairings for the front bumper, and the obligatory salt flat moon-dish wheels. The F-250’s drivetrain and transmission were stock."
That is in no way stock, "Drivetrain may refer to: Powertrain, the group of components in a motor vehicle that generate power and deliver it to the road surface"
So how is changing everything other than the block and heads make it stock?
It's called factory BS Phantom, not to be confused with the other 9,684 flavors of BS in the world.
