Ducktail had a tendency to lift at the rear so I had to screw through the metal bar. I will have to rethink how to fix this situation.
The Tyvek ended up separating from the driver's side on the cab and then shredded itself. Looked like a big cat had attacked it.
Will be looking fer some nylon today to replace it with later today. Hopefully it will make it down to Houston. It's raining out.
