Old 09-18-2011, 06:31 AM   #4 (permalink)
jakobnev
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 214.18 mpg (US)
Send a message via MSN to jakobnev
There should be a battery voltage feedback line separate from the thick high current line. What i would try is to build a circuit that keeps this line a couple volts above the actual battery voltage.
Simply unhooking it at the battery and and reconnecting it through a couple of NiMh in series might be enough, but you might want a more elegant solution that doesn't require you to keep them charged for the long run.
