Old 09-18-2011, 02:44 PM   #8 (permalink)
oil pan 4
I would say anything over 12 volts is good when cycling it. Depending on load that means you likely have not gotten into the bottom half of its capacity.
You want to make sure that battery gets a good charge when the car is home. The deeper you cycle the battery the quicker it will die.
As long as your solar panel can build over 18 OCV in normal day light it should be good for charging. I believe about 17 volts is the cut off for effective charging.
The solar panel I would like to build for my truck has a target voltage in the 18.5 to 19 ocv range. If it turns out to build between 19 or 20 ocv I wont be sad.
The under load target is 14.5v @ 5 amps.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
California98Civic (09-18-2011), redyaris (09-19-2011)
