Originally Posted by KUSAW
is it also can be used for 1KA DC controller?
control board is pretty universal - you just need to swap out the sensor for higher current one and use a different driver (designed for IGBTs, with negative bias).
You can then attach an IGBT power stage to it. You power will be limited by your ability to design a high-current power stage (which is far from trivial but can be done).
