Originally Posted by Joe1234
The tranny makes a rapid tapping sound even when it is in neutral. It goes away when the clutch pedal is pressed down. I'm guessing it is one of the bearings in the transmission.
Input shaft bearing. If it's like the one in my 1990, it requires disassembling the transmission and removing the input shaft seal to replace. Not immensely difficult, but it does take some time and effort.
-soD
