Old 09-19-2011, 06:44 PM   #27 (permalink)
hondaguy72
Enthusiast
It's the units that are on the ends of the main and countershafts. Main shaft comes out to the clutch, countershaft is in between the differential and main shaft. The one bearing that is in the case in the last picture should be staked in with a center punch once replaced.
full write ups are on d-series.org
http://www.d-series.org/forums/trans...ng-change.html
The Following User Says Thank You to hondaguy72 For This Useful Post:
Joe1234 (09-19-2011)
