The VSS signal from the transmission transducer on my '91 Ford is fairly weak. In fact, a couple months ago, the connector at the trans had gotten oil in it and that was enough to pull down the signal. I don't think i have a wire from the ECU to the speedo because i have a speedo cable too.
