Old 09-20-2011, 04:42 PM   #14 (permalink)
Daox
The alternator disable its a great mod. I wouldn't have hit 70+ in the Paseo without it. Good luck with your best tank!
BTW, as a general rule, 11.5V is the lowest you should take your battery if you're planning on deep cycling it a lot. This ensures that it lasts more cycles than if you take it down lower.
The Following User Says Thank You to Daox For This Useful Post:
California98Civic (09-20-2011)
