Old 09-22-2011, 10:56 AM   #79 (permalink)
jkv357
Originally Posted by Artan View Post
I am not saying that they degrade or upgrade. I am saying that to convince me that we need an oil change there should be a test with two same engines one with oil change and the other without. Drive them for certain amount of time and mileage, see the fuel and oil consumtion, open them and the internal parts of the engine for inspection if and how did they wear, compare and the result will be obvious. Its very simple. The labs are just saying the oil contains these kind of minerals and their amount. Thats it. There is no conspiracy, this is totally something else.
I do recall something similar, done with NYC Taxi cabs. One got regular changes the other did not. Guess what the difference was - not much...
But, that's not my world. Those engines are started once and run all day. That's easy on an engine - 1 cold start (minimal acids and unburned fuel), quick and complete warm-up, extended running to burn-off moisture - perfect.
If that's what I did daily I'd run my oil a long time too.
My engine's life isn't so perfect...
The Following User Says Thank You to jkv357 For This Useful Post:
Artan (09-22-2011)
