Old 09-22-2011, 02:27 PM   #6 (permalink)
Phantom
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
I just filled today for 29.74mpg and was 0.7 mi short of 500mi and still had over a gallon left in the tank. There are a few changes on the L26 namely the material it is built of aluminum preventing the coolant leaking issues. Also It has a longer inlet with a round opening instead of the butterfly opening and a slight taper to increase velocity. There is a user test on this and it shows that the VE is increased a bit with the new upper intake. So if I am porting the Lower intake to remove casting flaws I might as well change the upper and add a less restricting Throttle body that matches the inlet opening.
To note I had the LIM from my 03 GP and purchased the UIM and new TB for ~$20 each shipped, the biggest difference I noticed when installing them was better throttle response. Also the reason for going with the L26 UIM is I purchased the HV3 (intake insert) for my GrandPrix with the L26 UIM and I want to put that in the Bonnie.
I like my FE but it is fun to press the Loud peddle.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
