Old 09-22-2011, 08:18 PM   #83 (permalink)
Ford Man
Originally Posted by Artan View Post
Bring something new to the forum not these same things we hear everyday my friend.
Check this one; Oud-directeur Castrol: olie verversen onnodig | Krimineel.com
Something new, 518K miles (approximately 834K kilometers) on an engine without any rebuilds using regular oil change/spin on oil filter intervals (dino not synthetic). Name of thread 500K. This is my personal car. Show me someone that has done this with NO OIL CHANGES? Your example is approximately 155K miles, I'm just getting broke in at 155K miles. I've even had enough sludge problem over this mileage with regular oil/spin on oil filter changes I had to pull the oil pan off at about 515K miles to clean the oil pump screen, because the oil pressure had dropped to near 0. I cleaned the screen, CHANGED THE OIL AND FILTER and the oil pressure returned to about 60 PSI on a warm engine at 55 mph. There was also a significant amount of sludge in the oil pan that I removed. I know the affects of sludge first hand. This car has probably averaged 5K mile oil changes though out it's lifetime.
The Following User Says Thank You to Ford Man For This Useful Post:
Ryland (09-22-2011)
