Originally Posted by Lazarus
Installed. I'll see how it goes when it warms up a bit here.
Originally Posted by LostCause
I wonder what kind of deposits the misters will leave on the condensor coils. Like RH77 says, hard water will probably leave behind mineral deposits that could clog the fins. I've read that even with a polyphosphate filter, a white residue can form. In any case, if it gets to bad it will probably be easy to periodically clean it off with CLR.
Any thoughts on filling the filter( shown at the faucet) with vinegar to keep the hard water at bay? I imagine if you filled it once a month with as little as the mister put out it work work well with the timing change of the inside filter.
