Old 09-24-2011, 06:45 PM   #22 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Have you considered how large that your blind-spots will be in the new design ?
I threw together a quick Gimp paint-over of your original side shot, and it seems like with your line of sight in the car, you would only need a small section of the Kammback in clear lexan. The stuff is expensive, so this is good.
The rest could be formed in whatever material you decide to use and it could be pieced together in sections to form the compound curves.
The problem that arises is that you would still have massive blind spot along the side of the car. You could form the entire piece in Lexan, but it would be horribly expensive.
