Old 09-25-2011, 01:43 AM   #127 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Originally Posted by HighMPG View Post
I have 13" tires!!!!!!!!!!!
I can go up to a 185/60/14 and keep most of the spedo difference in check at .09% difference but the tires will get heavier and 1.1" wider which might reduce my efficiency/MPG and raise rolling resistance, un-sprung weight and other factors??
What I found is the rear wheel well is the ultimate, size determinant. As an experiment, buy one wheel and tire and then mount it in the rear and later, swap it in the front. You won't be driving far as much as taking measurements and then looking for a 'speed bump.' You want to make sure there is no interference on a bump or problems at steering limits.
GOOD LUCK!
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
