Originally Posted by some_other_dave
Well for what it is worth I have gotten misinformation from so many places I can't tell you including that site.
I have looked literally at least a hundred times or more to confirm which distributor the HF uses. Everywhere says the 1.5 engine HF included uses the TD 01U distributor. That is completely incorrect. The reason I was getting those codes is because that distributor has only 2 pick ups in it and the HF requires 3 just as the Si does. I installed and properly wired a TD 18U distributor and magiclly all the codes are gone the engine runs smooth and 90% of the smoke is gone.
I still don't understand why the Helms service manual and the Honda electrical manual have completely different pin outs for the ECU or at least different number locations.
Oh well I will have this car on the road very soon, just need a little exhaust work. Thanks Dave
