Originally Posted by HighMPG
Would possibly getting a taller tire then stock raise my MPG? I have not looked into it.
I am not a believer when it comes to tiny tires for MPG. I can not find any one that lost MPG by going with a slightly taller tire (less revs per mile).
Wider tires offer less rolling resistance with the same load.
At some point drag losses which increase by a factor or 4 every time your speed doubles will over come the lower rolling resistance which doubles with speed. I don't know where that point is, but I think it is roughly around highway speed for a car.
With a car you should be able to aeromod your way around the wider tire drag problem.
Also the idea of a small contact patch with a hard rubber compound does not inspire confidence with me.
I did the worst tire swap imaginable on my truck and I gained a barely detectable boost in MPG, that was going from a P235/75R15 that weighed about 26lb to a 2 inch taller 31x10.5R15 that weighed about 40lb. Both tires were made of hard compunds known for lasting over 60,000 miles.
When it comes to tires I have 2 rules.
#1, no tires made in china. Their quality control is garbage.
#2, no firestones, past performance is indicative of future results.
