Thread: Choosing a Tire
Old 09-25-2011, 08:07 AM   #9 (permalink)
HighMPG
HighMPG's Avatar
Super Duty - '12 Ford F250 Super Duty XLT Long Bed Super-Cab
90 day: 15.29 mpg (US)
Did you know the 155/80/13 tire is the OEM size for my corolla?
The 175/70/13 tire is smaller so going back to the 155/80/13 tire will be larger and match my spedo, this was just the comperable and closest replacement for the car at costco and they just put them on you know. It was when my exgf owned it. thanks for your idea but maybe you did not understand I am actually going back to stock size.
I currently have 175/70/13 size "Radial X" on it right now came with the car.
Section Width: 7" on 5" rim
Rim Diameter: 13 in 330.2 mm
Overall Diameter: 22.68
Sidewall Height: 4.82 in 122.42 mm
Radius: 11.32 in 287.52 mm
Circumference: 71.12 in 1806.4 mm
Revs per Mile: 917
I just found out 155/80/13 is the OEM size for my 90 Corolla Coupe.
Section Width: 6.10 in 155 mm
Overall Diameter: 22.76 in 578.10 mm
Sidewall Height: 4.88 in 123.95 mm
Radius: 11.38 in 289.05 mm
Circumference: 71.50 in 1816.1 mm
Revs per Mile: 913.8
Kumho - Solus KR21
Revs per Mile: 914
Weight: 14lbs
Maybe now you can see what I mean?
Good Bye Insight Hello 6.7 Diesel Truck!
**My First Hybrid Insight**
