Originally Posted by CapriRacer
Forget the "narrow is better" approach. Not only has that limited your choices, but it is fundamentally flawed.
Put the largest tire that will fit without rubbing. Discount Tire might be able to help you. On their web site, they list alternative tire sizes after you input your vehicle. Find the size with the largest load index. THEN look at your choices.
Thanks I may just get another set of Radial X if I can find them on my size since consumer reports puts them in their top spot for good RR.
