Old 09-25-2011, 09:56 AM   #9 (permalink)
Daox
Great testing Darin. Gotta love lean burn!
Originally Posted by Otto View Post
1. What's that car got for an undertray "as is?"
2. Batteries: What's the cost to replace the stock batteries? Would something as simple as Costco marine deep cycle batteries work as a suitable replacement?
3. If you just took the batteries out and ran without them, approx. how much weight savings? Fuel savings?
4. What tires, tire pressure?
1) The insight has some undertrays, its not nearly a solid/flat surface though.
2) He'll be rebalancing and replacing parts of the pack if necessary. There is a pretty good thread by RobertSmalls that tell you how to do it. You can not use deep cycle lead acid batteries.
3) The entire pack only weighs 65 lbs. Fuel savings from removing it would be nothing.
The Following User Says Thank You to Daox For This Useful Post:
aerohead (10-08-2011)
