Old 09-26-2011, 12:18 PM   #10 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
You're preaching to flock.
If you are getting real good fuel economy then your emmissions are likely well with in limits.
If you're talking about HC or CO, then I agree (because both are an indication of incomplete combustion).
Not true when you're talking about NOx. As a general rule, high NOx (pre-catalyst) and high efficiency go together.
Particulates (on a diesel) are a mixed bag. High engine-out smoke is like HC & CO--an indicator of inefficiency & unburned fuel. However, the addition of a diesel particualte filter (DPF) will hurt your overall fuel efficiency via higher back pressure and fuel used in filter regenerations. So low smoke generally means better efficiency, but ultra-low tailpipe smoke (via a DPF) will give you lower fuel efficiency.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following User Says Thank You to Diesel_Dave For This Useful Post:
Cd (09-29-2011)
