Thank the tuner world for advancing the air ride technology. Now a days you can get an air ride suspension for any vehicle. I have on eon my Scion and with proper adjustment I can go from pancaking the body kit flush with the floor to 3" above stock height, which is how I get it on and off the trialer. These kits come with electronics that allow you to monitor individual strut pressures as well as allowing to set and lock pressures digitally, even with presets.
Plus you get the added bonus or air ride, which is alot smoother than your standard shock and coil suspensions ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
