Old 09-30-2011, 06:45 PM   #32 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Originally Posted by MPGranger View Post
So I just need to eyeball the engine loading then?
Also, if I hit 99 LOD with the accelerator half depressed, what happens when I continue to press the pedal?
It means you've removed the throttle as the biggest restriction in the system. The intake, air filter, valves and/or something else are holding it back.
It also means you need to back off the throttle. Most fuel-injected cars enrich the mix at full throttle, putting in extra fuel that doesn't burn. That extra fuel is wasted.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
MPGranger (10-01-2011)
