Old 10-01-2011, 08:45 PM   #5106 (permalink)
evimarn
I would like to thank all who contribute and share their knowlegde especially those who answer my questions (silly at times).
I would like to see listed the most reliable D.i.y. units using igbts and pwm gens and drivers with schematics as this helps me choose. ( I have most spec sheets for components ) after your experience and expert advice, since I cannot afford to do p.c.bs and trials ,for various reasons.
So I am after a complete d.i.y. set ,not that I will be using it for max power but might be over loaded at times.
I am intending to use a freelander starting at 144 - 168 volts and a Kostov motor, hence the realabilty I need is if I up the voltage for later on I would like to keep the same system, but mostly because whatever I get usually c*aps on me so I strongly believe a well designed / built system by you, and using igbts will have a lesser chance of screwing me up. hehe.
Please do not flame me I need a lot of input.
Cheers.
