You may need to inflate closer to 44psi which is right around max Psi for most 15" tires. I generally run 50psi on my 15s (max rating of 44psi). This has dramatically increased the rolling distance on coast downs.
Comfort is ultimately more important so go with works for you. I quickly grew accustomed to the extra harshn.
