Old 10-02-2011, 01:30 AM   #6 (permalink)
malovich
Still a noob.
Teddy - '97 Suabru Legacy Outback
90 day: 26.84 mpg (US)
the 28 was merely from the scangauge on my most recent tank 98% highway but upon fill-up tonite (same tank as 28) I got 25 fwiw. My tires are a bit low since it's colder out and who knows how accurate my fillup was and my speedo is off (68 actual registers 70 so about 3%)
On second thought the bedliner may help a hair like a golfball if it is rough. My abs started acting up so I pulled that fuse which also kills the CC so I've been without CC for about 30K miles. It's not much strain to drive with your foot on the pedal as long as you are merely applying a constant pressure/position while allowing the speed to fluctuate, works for me.
I know the fin was a jk but the crosswinds would suck.
