Old 10-02-2011, 01:28 AM   #7 (permalink)
Peter7307
First up: Welcome to the place and enjoy your stay.
One item not addressed is the cruising speed.
65 is fine but your economy should be better at about 55 / 60 since this will allow you to stay in 4th. gear and keep the revs down a bit as well.
As you probably worked out already it is usually a matter of "a little bit here...a little bit there" to get to your MPG target.
Good luck and post what you find.
Peter.
