Originally Posted by Patrick
And by gearing up you require a larger throttle opening, eliminating the additional pumping losses you originally created.
No it doesn't. Taller gearing means lower RPM for a given speed therefore reduces manifold vacuum (higher absolute pressure) and reduced pumping losses. The amount of power to overcome rolling resistance and aerodynamic drag remains the same.
