Old 10-03-2011, 06:31 PM   #18 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
bwilson4web,
I thought you might want to look at these links
Infinity Turbine ® - Organic Rankine Cycle Model ITxr Kit
or this
ITmini Experimenters Kit
You can't bolt this onto the exhaust but you can create a closed system loop system using refrigerant. You might also be able to tap heat from the radiator.
The Following User Says Thank You to ConnClark For This Useful Post:
bwilson4web (10-03-2011)
