Old 10-03-2011, 05:58 PM   #229 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
I found this while websurfing today.
Infinity Turbine ® - Organic Rankine Cycle Model ITxr Kit
you can't run it directly off your exhaust but you can hook it to a closed loop system or maybe a single pass system. This company suggests using it with a closed loop organic rankine cycle using refrigerant as the working fluid. They also say you can recover heat from the radiator alone.
