Old 10-03-2011, 10:15 PM   #15 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Originally Posted by tjts1 View Post
No it doesn't. Taller gearing means lower RPM for a given speed therefore reduces manifold vacuum (higher absolute pressure) and reduced pumping losses. The amount of power to overcome rolling resistance and aerodynamic drag remains the same.
Power remains the same, but RPM is lower, therefore torque must be higher, requiring a larger throttle opening.
