Originally Posted by Vekke
....When driving on the uphill I try to keep my instant fuel gauge at some point. Target is let the speed slow down slightly all the time. 1km/h per second is good time to lose speed. So I use glide with load as I call it.
This is my approach as my pulses are not good uphill, no turbo these days
so I try and take a run at it on the flat and then hold the MPG at a minimum target and only increase it if I hit my minimum speed.
Must watch the videos later, Youtube blocked at work.
If you want a cheap camera those chinese $20 handheld ones with a 4 or 8GB micro SD card work reasonably well - loads on ebay. An alternative is to use your phone video camera with a windscreen mount or mount it on the headrest poles, or the headrest itself although it shakes a lot like this.
EDIT - Or you could just wave it around like Vekke....
