Old 10-04-2011, 09:19 AM   #9 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Replacing the transmission is not much more work then replacing the clutch, so if you are already prepared to do the clutch you might just do both.
A bad bearing in the transmission is going to give you poor mileage as well, if it's the main bearing then it could be leaking fluid on the clutch causing it to slip.
