Originally Posted by tjts1
No, with taller gearing for a given road speed, you still need the same amount of air to send the same amount of torque to the wheels. RPM decreases, absolute manifold pressure increases, throttle angle remains the same, torque remains the same. On a naturally aspirated engine you reach you peak torque for a given RPM when manifold pressure is at 100kpa regardless of the throttle angle. At low RPMs you can reach peak torque at 30-50% throttle.
Power = torque X RPM. If you decrease RPM, you
must increase torque to maintain a given power.
