Old 10-04-2011, 05:33 PM   #20 (permalink)
tjts1
Originally Posted by Patrick View Post
The equation holds at any RPM, torque, or power. Just like E = I X R, it's a mathematical and physical fact. If you decrease rpm for a given power, you must increase torque. If you lower RPM at the same torque, you have decreased power.
Ok if you say so but this has nothing to do with throttle angle or the amount of air consumed. Throttle angle stays the same, MAF load stays the same given a fixed speed and taller gearing. If you don't believe me, try it on your own car. Its very simple test. Anybody with an OBD2 can do this.
