Old 10-06-2011, 09:30 AM   #586 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by CollinK View Post
The control software is open, the driver boards are open, and a reasonable control board will be open.
Are you referring to Powerex BG2A reference design PCB, and dual VLA500 Gate Driver PCB’s as open? Or are you going to design you own Gate Driver Interface? It would be nice to replace that Powerex stuff with a new low cost, open source Gate Driver Interface.
Technically Paul had schematics of an earlier design for a control board posted. But, a lot has changed since then.
Is this the base AC Controller Schematic you started with? https://www.onlinefilefolder.com/1sYLaUVLcWOoiL
I'm working on schematics and board layout for a newer design
Will it still be a dsPIC base AC Controller?
Keep up the good work
-Mark
