I always add Stabil to every can when getting gas for my small engines, as I don't go through it that fast. Always make sure the can is tightly closed as well.
I've recently found Regular gas without Ethanol that I use in the cycle and small engines.
I also drain the gas from the small engines, run them dry, and change oil before storing every year. They always fire up immediately when needed.
As it gets colder I make sure to use up all of the summer gas that I have sitting around. If you happen to have a small generator, be sure to swap the gas regularly from summer to winter (and back) every year and run it - before you need it
Simple stuff that saves problems and headaches later.
