Originally Posted by California98Civic
Excellent. Hey, did you notice the car at #3? I was just checking your position and started looking at others fuel logs... the Metro at #3 ... the owner stops recording fuel data in late summer early fall and does not pick up again until mid/late spring! Hahaha!!
For this winter I have bought a 4 amp 'Inteligent' battery charger that I will mount in the engine bay and plug in with my block heater at home and work, because of EOC in the dark, morning and evening. I will also try to install some form of solar panel battery charger. The problem I have had in the past with solar panel battery charging, is that the battery discharges at night through the solar Panel. I think that by instaling a charge controler I can avoid the discharging. The task at hand is to minemise the affect of winter on FE...
