Old 10-08-2011, 03:47 AM   #112 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Currently working on my version of an active grille block. I am going for a fully automated version using two 12V door lock linear actuators. I want it to be governed by a temperature relay, meaning it would only open when the coolant starts flowing into the radiator (circa 184F).
There will be 2 small leds. Blue for cooling (open grille) and red for warm (closed grille). Still have to figure the necessary electronic components and circuit/wiring diagram. Shouldn't be too hard given my avionics background !
Basically, the two actuators will push and pull my previously made and unused foam grille block (the middle one). I figured it must be put to good use ! Stay tuned for more info and schematics in the coming days !
The Following 2 Users Say Thank You to CigaR007 For This Useful Post:
Daox (10-09-2011), jime57 (11-09-2011)
