Old 10-09-2011, 10:15 AM   #115 (permalink)
Tango Charlie
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
You may get better airflow if you round corners and put the plug behind the opening like this;
I would also suggest spring loading the block to the open position as a fail-safe.
Also, maybe you could get a larger opening for the same actuating distance if you use a cone-shaped plug? I dunno.
-Terry
The Following User Says Thank You to Tango Charlie For This Useful Post:
aerohead (10-10-2011)
