Old 05-17-2008, 01:44 AM   #5 (permalink)
JohnnyGrey
Pushrod - '02 Chevrolet Cavalier
MAF may be easier to calculate, but it's no more accurate than MAP+RPM. The SG is still unaware of fuel cutoff, cold start / open loop enrichment or decel lean-out. Also, on my car (which has no MAF sensor), it tends to overestimate the effect that intake air temperature has on fuel volume. When the weather changes rapidly, I notice it's off by more when I go fill up. Until the OBD standard has an injector pulse width parameter that is widely supported, FI + VSS will always have the advantage in accuracy.
