Peterj, you mean
this?
As for other ways of doing this, especially if you don't have a MAF sensor, by knowing the displacement of the engine, and after a simple "calibration" using fuel tank "fill-up" data to find the only unknown, namely the "volumetric efficiency" (VE) of the engine, MAF can be calculated from RPM, MAP and IAT. With VE, one can use the following formulas to calculate a synthetic "mass air-flow" (MAF) in grams per second, all without a MAF sensor, using the "Ideal Gas Law", as follows:
IMAP = RPM * MAP / IAT
MAF = (IMAP/120)*(VE/100)*(ED)*(MM)/(R)
where manifold absolute pressure (MAP) is in kPa, intake air temp (IAT) is in degrees Kelvin, R is 8.314 J/°K/mole and the average molecular mass of air (MM) is 28.97 g/mole. Note that, in the above formula, the volumetric efficiency of the (4-cycle!) engine is measured in percent and the engine displacement (ED) is in liters.
You might be on to something Johnny, not that you need me to tell you that
But I wonder if the short term and long term fuel trim can be used more accurately predict the fuel consumption in changing conditions.
