Old 10-10-2011, 08:37 PM   #8 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
Originally Posted by Rick Rae View Post
If the Canyon has drive-by-wire, have you looked at any of the so-called "throttle controllers" ("APPS response warpers," more accurately) to see if they'll do what you need?
Rick
I hadn't realized that such gadgets existed until you mentioned it. I found a couple with an "Eco" mode that is a step closer to what I'm looking for, but nothing that gets all the way there.
Most of my driving is between 700 and 1900 RPM. In that range, I want the torque to be linear to accelerator pedal position. This is tricky because the relationship between accelerator pedal position and throttle blade position is a function of engine RPM. At low RPM, you get 90% torque with the throttle open less than 20%, while at high RPM the throttle might need to open over 80% to get 90% torque.
Maybe it's time for me to learn how to work with an Arduino....
