Old 10-11-2011, 02:25 PM   #1 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Easy way to tell when fan is running while driving
I have a clutched fan on my truck. I believe the clutch is electrically controlled. I'm thinking I may be able to improve my FE by turning it off when it's not needed. An electricl fan is an option, however, if the clutch is electricallly controlled, I should be able to just use that to control the fan better (which should be more efficient than an electric fan). Before I do anything, however, I want the check and see how often the fan is running "unnecessarily" as it currently is.
It's a pretty quiet fan, so I can't hear it over the engine. Does anybody have any tips for a quick and dirty way to tell if the fan is running (while driving)?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
