Originally Posted by California98Civic
BTW, there are some mods you can do that won't change your look at all, or make it kinda cooler. An undertray cannot be seen at street level, for example. Tire pressure changes are not visible. Injector kill switches can be hidden very well.
Okay I'll check that stuff out.
I know I need better tires for FE, however its getting toward the rainy season up here in washington (aka not august of sept) so will probably keep the all seasons on til spring. I'll try raising the pressure some they're only at about 30-32. As for an under tray I did see that I'll have to find a shop up here that can fabricate something like that and see how much it runs.
Thanks for the tips!
