Originally Posted by ConnClark
I found this while websurfing today.
Infinity Turbine ® - Organic Rankine Cycle Model ITxr Kit
you can't run it directly off your exhaust but you can hook it to a closed loop system or maybe a single pass system. This company suggests using it with a closed loop organic rankine cycle using refrigerant as the working fluid. They also say you can recover heat from the radiator alone.
THAT is cool! how much is it?
You could simply wrap a coil of copper ALLL around your exhaust pipe and route it to this.
