10-12-2011, 01:21 AM
EPA has approved E15 for cars newer than 2001
E15 (a blend of gasoline and ethanol) | Fuels & Fuel Additives | US EPA
i have not seen this posted here , if it has been , i apologize ...
i was looking for something that may cause an extreme drop in FE for the last few tanks of fuel .
my system does not show any symptoms of problems and intake vacuum is right at about 20" at hot idle , where it has always been ... no DTCs or changes in fuel trim values ,brakes do not drag , tire pressure at 50psi , verified , yet FE is down .
no labels on the pumps where i buy fuel are claiming E15
i use only Shell top tier fuel .
not cold here , yet , 70f in the day time 50f at night
no doubt , E15 will not improve FE .
