Hi Collin! Sure you can post anything you want that's from me (driver boards for example). What are you using for the current sensor? If you are using LEMs, a LEM 300 would only have a voltage output change of 2.5v +/- 0.625v for a current range of -300A to 300A. They also have a LEM 50, and you can do 2 wraps around the lem 50 so it becomes a lem 25, or 10 wraps for it to become a lem 5, so that +/-5 amps would mean 2.5v +/- 0.625v.
